Cumpar piese lego
SeaGerz0r
Cumpar piese lego
Mesaj de SeaGerz0r » Dum, 11 Ianuarie '15, ora 22:29
Salutare tuturor. Am nevoie de cateva piese pentru a construi o macheta destul de complexa. As prefera sa le gasesc local, sa nu ma complic cu transporturi (posta) internationale.
3 x 88003 Power Functions L-Motor
2 x 6020086 Electric, Power Functions Receiver Unit Version 2
1 x 8879 Power Functions IR Speed Remote Control
2 x 11455 Black Technic, Pin Connector Perpendicular 2 x 4 Bent
1 x 92693c01 Technic Linear Actuator Mini with Dark Bluish Gray Head and Orange Axle
2 x 62531 Yellow Technic, Panel Curved 11 x 3 with 2 Pin Holes through Panel Surface
4 x 11954 Yellow Technic, Panel Curved 11 x 3 with 10 Pin Holes through Panel Surface
2 x 731c04 Yellow Technic, Shock Absorber 6.5L, Complete Assembly - Hard Spring
1 x 48452cx1 Turntable Large Type 2, Complete Assembly with Black Outside Gear Section
4 x 44809 Black Technic, Pin Connector Perpendicular 2 x 2 Bent
2 x 4589 Black Cone 1 x 1 without Top Groove
2 x 41239 Yellow Technic, Liftarm 1 x 13 Thick
6 x 41239 Black Technic, Liftarm 1 x 13 Thick
5 x 32525 Dark Gray Technic, Liftarm 1 x 11 Thick
2 x 32525 Black Technic, Liftarm 1 x 11 Thick
15 x 40490 Dark gray Technic, Liftarm 1 x 9 Thick
+ setul 42028 complet. Nu trebuie sa fie nou
Multumesc frumos,
Mihai
