Un joc cu intrebari
Re: Un joc cu intrebari
Mesaj de lapsanszkitamas » Vin, 03 Aprilie '15, ora 13:08
Bravo, ai dreptul sa pui urmatoarea intrebare
furnica98
Mesaj de furnica98 » Vin, 03 Aprilie '15, ora 16:08
intrebarea este grea
in ce film din seria jackie chan de pe PRO TV apar scene de lupta intr-un magazin de lego ?
PS: raspunsul il accept si simplu filmul (numele) nu trebuie neaparat filmul 2 sau 3 .....100 :D
furnica98
Mesaj de furnica98 » Sâm, 04 Aprilie '15, ora 16:20
raspunsul este politist la ananghie (2004)
dovada aici
https://www.youtube.com/watch?v=3A5yZlMBAO8
alta intrebare din ce an nu se mai fabrica seturi lego system?
iceflashrocket
Mesaj de iceflashrocket » Sâm, 04 Aprilie '15, ora 20:20
1999...dar trebuia sa zici de cand nu se mai foloseste logo-ul "System",ca daca stai sa te gandesti,Lego System inseamna orice e compatibil cu mini-figuri,adica din 1978 pana acum.
Mesaj de lapsanszkitamas » Sâm, 04 Aprilie '15, ora 23:51
iceflashrocket scrie:din 1978 pana acum.
Cautati pe interweb si aflati acolo raspusnurile ;)
Brickipedia scrie:LEGO System along with TECHNIC, is The LEGO Company's main line of building elements, minifigures and sets, and features the iconic standard LEGO brick which evolved from LEGO's first series of Automatic Binding Bricks that first appeared in 1949. The new pieces were first marketed under the name LEGO Mursten in 1953 and from 1955 to 1970 in the System i Leg series of toys. Later it was simply known as LEGO System. Most System bricks can be used with TECHNIC bricks.
LEGO System is also the brand under which most standard minifigure-compatible sets are marketed since 1978. The pieces in this line are smaller than DUPLO blocks. The iconic logo of LEGO System wasn't featured on boxes and catalogues until 1992. Most newer minifigure-compatible sets no longer feature the logo, although they are still considered a part of System.
Ultima oară modificat Sâm, 04 Aprilie '15, ora 23:57 de către lapsanszkitamas, modificat 1 dată în total.
furnica98
Mesaj de furnica98 » Sâm, 04 Aprilie '15, ora 23:52
ok ai dreptul la urmatoarea intrebare
