Cumpar canistre, instructiuni, piese BIONICLE!
Gaby
Mesaj de Gaby » Lun, 28 Ianuarie '13, ora 19:43
Dupa cum spune si titlul ma intereseaza cutii( canistre) bionicle, insturctiuni in conditii bune ( neindoite, rupte, mototolite) si in special piese BIONICLE.
Ma intereseaza doar anii 2001-2006. Va rog spuneti-mi pe PM ce aveti si eu consider daca imi trebuie sau nu. As dori sa cumpar in lot ca sa nu platesc taxe postale aiurea.
Piese: 1x 32533pb143 Bionicle Disk, 143 Ta-Metru Pattern
2x 32174 Technic Axle Connector 2 x 3 with Ball Socket
4x x201 Technic Ball Joint
1x 43853 Technic Bionicle Mask Nuva Hau
3x x345 Technic Bionicle Shoulder Armor
4x 32475 Technic Connector Block with Ball Joint 3 x 6 x 2 & 1/3, Bionicle Foot Socket
4x 32034 Technic Connector for Axle and Pin, Angled Size #2 180 Degrees
12x 32270 Technic Gear 12 Tooth Double Bevel
4x 32269 Technic Gear 20 Tooth Double Bevel
1x 3961 Round Dish 8 x 8 Inverted
4x 3749 Technic Axle Pin, Smooth without Friction Ridges( de preferabil pe negru)
3x 32553 Technic Connector Block 3 x 4 x 1 & 2/3, Bionicle Head
3x 32554 Technic Connector Block Eye, Brain Stalk, Bionicle Head, Brain Stalk (with granular eye serface) ( diferite culori)
4x 32039 Technic Connector with Perpendicular Axle Joiner
1x 32571 Technic Bionicle Mask Kanohi Kaukau
1x 6041 Propellor 3 Blade 3.5 Diameter, Propeller
1x 43557 Technic Limb Hinged with 2 Ball Joints, Bionicle Toa Nuva Leg Section
1x 44031 Bionicle Weapon Aqua Axe
1x 50899c Bionicle Rhotuka Spinner, Solid Color - Without Code on Side
1x 3708 Technic Axle 12
2x 50900 Technic Bionicle Rhotuka Spinner Ripcord 12L with Hand Grip, Connector Block 1 x 3 x 5
2x 6632 Technic Beam 1 x 3 Liftarm with Thin Profile, One Pin Hole and 2 Axle Holes( portocalii)
1x 32523 Technic Beam 3, Liftarm Thick 1 x 3
1x 50901 Technic Bionicle Rhotuka Spinner Holder 1 x 3 x 2 with 2 Pins and Axlehole, Connector Block Axle Hole
1x x1307 Technic Bionicle Rhotuka Spinner Rod 2.5L with Gear 8 Tooth (galbena)
2x 47300 Technic Connector Block 1 x 3 Bent with Two Ball Joints and Axlehole, Bionicle Joint 90 Degree 2 Axle hole 3 x 3 x 2
biopedia
Re: Cumpar canistre, instructiuni, piese BIONICLE!
Mesaj de biopedia » Sâm, 02 Februarie '13, ora 18:32
nu te intreseaza piee de bohrok makuta toa metru barraki ca am destule
Utilizator banat - vezi motiv
Gaby
Mesaj de Gaby » Dum, 03 Februarie '13, ora 16:19
Pai ma intereseaza ce scrie acolo. Daca crezi ca ai ce-mi trebuie atunci evident ca da. ;)
biopedia
Mesaj de biopedia » Dum, 03 Februarie '13, ora 17:43
o sa fac niste poze
Localitate: Moisei. Maramures
Mesaj de badgogo » Lun, 04 Februarie '13, ora 00:49
Piesele notate cu Ok ti le pot da eu:
2x 32174 ok
4x x201 ok
1x 43853 ok
3x x345 ok
4x 32475 ok
4x 32034 ok
12x 32270 ok
4x 32269 ok
1x 3961 ?
4x 3749 ok
3x 32553 ok
3x 32554 ok
4x 32039 ok
1x 32571 ok
1x 6041 ok
1x 43557 ok
1x 44031 ?
1x 50899c ok
1x 3708 ok
2x 50900 ok
2x 6632 ok
1x 32523 ok
1x 50901 ok
1x x1307 ok
2x 47300 ok
Pretul 20 lei + transport (posta romana) vreo 6-7 lei.
Mai pot sa-ti ofer si ceva carti cu instructiuni.
